Help?
Any changes I should make?
http://pcpartpicker.com/p/YkKdGX
Also it's pretty much just for gaming
There are a few things that I don't particularly like -eh- but I'm only going to mention one thing. You need some overhead for the power supply. Just because pcpartpicker says a certain wattage doesn't mean it's fully true. The wattage during a load could be 100w more! You should get a power supply that is at least 700 or 800 watts just to be secure.
no , you really don't need 800 / 700w.
500w - 600 is fine for this build .
You're right, but it is always better to have more than you need. It not only can save your entire rig (if the wattage was to raise above power supply limitation you could fry all your components) but it also leaves decent room for expanding. You do need 600-700w but in my opinion, 800w would be best.
I agree with tomporter_, better to have more than need. I ran into the problem where it was time to upgrade and had to buy a new psu. I got set back 150$ so its best to spend the money now and have a good cushion.
At this budget, you can get better performance, but you might not have as fancy of a case.
http://pcpartpicker.com/p/Y8c7sY
Thanks! That's actually really helpful
