Help
I have an fx 8350 with a corsair h55 on an asus sabertooth 990fx r2.0 mobo. I have it on asus optimal and it is running at 4.34 Ghz and i decided to run prime 95. At the biggining it was alright but after test 12 where it began again from the top worker six stopped and said: error illegal sumout and possible hardware failure. It went up to 57 C
what does that message mean ? is there a problem in the cpu?
this is the result file:
[Sat May 10 11:37:52 2014]
Self-test 8K passed!
ERROR: ILLEGAL SUMOUT
Possible hardware failure, consult readme.txt file, restarting test.
Maximum number of warnings exceeded.
[Sat May 10 11:53:33 2014]
Self-test 10K passed!
it means that your cpu is unstable. I would happy to help you make your cpu OC stable but we are going to need where your voltages and other settings are currently.
