Hello guys help !
So i just updated my setup by changing my motherboard, ram , cpu. So i boot up my pc and load up windows. It goes to to loading loading w7 and about half way it freezes and for 1 seconds there's the blue screen of death. Then it reboots en asks me to repair w7 i do it but it doesn't help? What sould i do sould i update my bios?
What did you update from, and what did you change to?
After you install Windows it automally gets the drivers from internet. Now that you changed the Hardware the drivers windows loads don´t match and it pretty much gets confused as the software don´t match the Hardware and gives BSOD.
Reinstall Windows...
OR boot up in safe mode, use driver sweeper and install proper drivers.
