computer has been doing this thing where it will kinda shut off.. i lose all i/o ports and power button. the only way to turn off at this point is to unplug or switch off psu.
its starting to get pretty annoying and i was wondering if it was the windows 7 os i downloaded from this link
http://www.w7forums.com/official-windows-7-sp1-iso-image-downloads-t12325.html
or its my mobo, although im quite sure its the os.. ive updated it too
please help.thanks
Well that site does seem kinda dodgey, Install Ubuntu and see if that fixes it, you will then be able to see if or not it is the copie of windows you have.
i would say first try to download a diffrent image.
like the windows 7 x64 ultimate. burn to dvd and try to install it. if a diffrent image is causing the same problem, then it might be probably a bios issue. or like said above try an unbuntu linux open suse or linux mint. and looks if it works fine then.
