Ok, I'm getting a GPU that it's minimum power supply says 500W. Would a 550w PSU be fine for this card?
Should be just fine, 'the minimum powersupply wattage' thing is generally kind of meh... It's just there to make sure you don't get a 200w psu I guess...
But the 550w PSU Is mighty fine as, long as you get a good brand!!
