So I downloaded Synapse for my naga razor and my laptop crashed.
and it says Reboot and select proper boot device or insert boot media in select boot device
anyone know how to remedy this?
BIOS
intel rapid storage technology
RAID Volumes:
Volume1 RAID0 ( Stripe ), 476.6,
make sure bios is booting from harddrive(hold F2 or del or something while booting), otherwise, give us some more info as Ra$er installs shit based on OS with synapse(AKA install legacy drivers instead).
it seems like one of the raid drives failed.
not what info you are looking for will post pictures as soon as my phone get enough juice.
on your boot tab in bios, whats your default boot device?
It says the same under option 2.
I bought this laptop with 2 M.2 in raid 0
From ibuypower. They made those the boot drive also it seems like one of them unaided itself or failed. @tnomlebsuiram
there's your problem.
make sure your hardrive is selectable as a boot option(probably in advanced or main settings).
hmm. unfortunately, hardware failure can't really be troubleshot...
can you boot onto the m.2 with raid disabled? either in ide or ahci mode?
I am going to call ibuypower tomorrow. I purchased this in January of this year it is still under warrenty . if it weren't under warranty I would attempt what you are asking. Thanks a lot for all the help @tnomlebsuiram .
