Yeah... I have this SaveShare virus, I think I possibly got it from looking a Trucks and such, but Currently I don't really have much for protecting my PC, I need help on finding a good program that will remove everything bad :S
Thanks.
Malwarebytes.org is a good program For Removing viruses.
Trucks?!! That's either a first for me or an epic euphemism for pr0n...
Trucks for sure haha, Just bought a Dodge Ram 1500
:P
Yup, Malwareybytes is great for removing viruses. And Avast is a pretty solid program for keeping them off of your computer. Although, you still need to take a few extra precautions. Make sure you don't download things from shady websites, don't open weird emails, and practice safe surfing habits while on the interwebs.
Unfortunately your not going to find software that will remove "everything bad". But you do have some good suggestions above that you can start off with first to see if they get removed. You can use some of the software below if you would like. You can also try sysinternals autoruns software to see all the autoruns on your PC including registry keys and such.
Malwarebytes : http://www.malwarebytes.org/products/malwarebytes_free/
Avast: http://www.avast.com/en-us/index
Avira: http://www.avast.com/en-us/index
Spybot Search and Destroy: http://www.safer-networking.org/
For safer browsing I would try some addons for your browser. Like Ghostery, NoScript, AdBlock Plus, and many others for Firefox or Chrome.
I use a mixture of different extensions for my web browswer. I use WOT to help me avoid bad websites and AdBlock plus. I 2nd avast for viruses and Malwarebytes for the rest
virus master race too stronk
What I used to do in a place I worked was as someone mentioned above get combofix from bleepingcomputer, but what I done first was get Rkill (also on bleepingcomputer) then combo fix then do a scan with malwarebytes or a similar program.
