I need help with my ssd. Whenever i boot up my pc, my bios says that my SMART status is bad and that i should back up, and replace. And to boot into windows i have to going directly into bios, click on boot option and manually click on my ssd. The ssd that i have is a Kingston HyperX 3k.
If SMART says your drive is bad, it's bad. SMART is a failure detection system meant to prevent data loss (http://en.wikipedia.org/wiki/S.M.A.R.T.). when your drive is ready to die, or is showing signs of dying, SMART says nope and prevents you from reading/writing to it. Ignoring it and forcing yourself to use it is the number one way to lose data. Stick it in another computer, back up the drive and replace it.
