So, the other day I was messing around with my flashdrives, trying to install some linux distros on an old pc. I have no idea what happened but, my 8gb kingston data traveler memory stick is now only showing up as 446 mb in my os (windows 7).
Does anybody have any idea what caused this or how to fix it?
the partitions might be screwed up, use a partition manager to fix that
A yes, there are around 5 different partitions, thanks. However it won't let me merge the partitions with windows disk managment.
google minitool home partition manager
use gparted or EaseUS Partition Manager Home Edition (which is free)
I was messingaround with a few partition managers, EaseUS seems to have done the job, thanks guys.
