Help with planning my first build?
Hi, Am am wanting to plan for my first pc build that i plan to fund with Bitcoins! (If my system that is running on a year or 2 old hardware can handle) Or with B-day Cash. The Budget of the build is as far under $800 as possable using SSD/Msata SSD's Later on i can get a TB HDD. This is the build i have so far.
LINK:http://pcpartpicker.com/p/JSye
Thanks.
Samuroot1987
Here I made this build and it runs circles around you build as well as only costing $30 more! First thing, never go with AMD FX 6200 bulldozer or the 6100. Go with the Piledriver AMD FX 6300 or 8320(if you can afford it). I switched out your motherboard with a better one. Never choose a single stick of RAM because it slows down your computer. I changed you SSD to better known/more reliable one(with extra gigs of space=D) I also changed you graphics card to the 7870xt because it the best price to performance GPU and its basically a 7950 for cheaper! For your build you do not need a $100 case so I choose a cheaper case, but choose a case to your liking ofcourse because you have to look at it everyday, but I recommend you choose a mild price ATX case.  I changed your PSU to a Corsair 600W just because it was $10 more and it was 80+ bronze certified which it ensure the longevity of your computer. I also added a CD/DVD drive.
http://pcpartpicker.com/p/JUzx
Something that's under $800 don't waste 10% of the money on a liquid cooling solution, especially if its a single rad, even if it's thick. Just grab a giant air cooler for not even half the cost.
Yeah, I've seen an idiot config a build with a kraken x60 for his fruckin athlon. I wanted to choke a bitch
I agree with that. Just grab a CM hyper 212 evo for $30 or a Xigmatek Dark Knight for $40.
Im new :P dont know how things will preform. So i get things ive heard are good
Can you guys fint the EVGA stinger on pc part picker? i cant
