Help with PC to TV
Hey guys I have an old CRT TV that I want to hook my PC up to so that I can Game on a bigger screen (I dont care about the resolution) can someone help me on how I can go about doing this? I have a GTX 760 as my GPU and I hope someone knows a solution.
Depends on what connections your tv has. Youll most likely need a crt out converter box for about 20 bucks or more, the video quality might be not that great though.
im not really concerned about having hd quiality but can you give a link to one
can you post pics of the connectors on the back of the CRT?
Prolly need 2 adapters: scart to vga and vga to dvi
I'd recommend buying a second hand monitor.
I'm wondering about this too, thinking about using an old machine as a mame box and want to use an old crt for authenticity.
here's where i was going for authenticity...
rf switch
its a rca reb white and yellow
Do you have an old VCR with a s video in? Get a converter cable as shown above,then run the red/white/yellow from that to your tv. There are a bunch of ways to do it, but nobody does anymore...
i think crt's are roughly 480x640. games will run super fast.
while you're at it you can get one of these as well...
That way you can listen to the audio though the tv (or surround sound system, like I do) as well!!
