I need help with my PC build. Is this good enough, etc? I plan on getting another 690 soon enough and I just want to make sure it doesn't overheat, etc.
The specs:
The specs:
how much do you have to spend? are you only gaming? any parts you can get from an old build? eg harddrives disk drives ect
I have $3,200 to spend. I am not only gaming, 3D modeling, rendering, streaming, etc. I also don't have any old parts I can get.
what programs are you going to be using?
http://pcpartpicker.com/p/KObH AMD build
http://pcpartpicker.com/p/KOhc Intel build
you can switch around the graphics cards if you wish, the case, keyboard, mouse, mouse mat, montior are all personal preferance, so change to something you like
