i want 4.4 on CPU 2.4 on NB. i have overclocked but trouble is when i run prime95 the cpu throttles down to 1.4ghz after about test3. i run the second option for maximum heat and consumption.
at 4.5-4.6 it would hit 60 as well. but mine is running on standard mode. which under load the rad fan goes up to ~2000 rpm and my case fan ~3000 rpm which is right above the rad and VREGs.
the vregs and northbridge chipset don't get hot i keep them quite cool with the fan at 3000 rpm.
mine hits 4.4 ghz at stock as well but i will have to increase the load line calibration and increase the capacity to 120-30% and LLC to high-ultrahigh
