Help with new system
I am building a new pc and having trouble deciding on a cooler for a 3570k, i want to get around 4.5ghz.
And no I don't want a 2500k.
My budget for the cooler is around $50-60.
I was going to get the 212 Evo, thoughts?
I also still havent got my motherboard, thinking about a asrock extreme 3.
Specs:
CPU: Intel 3570k
GPU: HIS 7950
RAM: 8gb Corsair vengence
PSU: OCZ 550w 80 plus
Mainboard:
HDD / SSD: 1tb seagate, 120gb vertex 4
CPU Cooler:
Case: Rosewill Thor v2
cooler http://www.newegg.com/Product/Product.aspx?Item=N82E16835103176
I like this one to fyi Blue led (keeps my friends 2600k @4.6 under 70c and quiet ) http://www.newegg.com/Product/Product.aspx?Item=N82E16835118091
but if your cass will fit a h100 go for a h100
the Thor v2 is not that good of a case.
Corsair Vengeance Series C70 comes in black, white, and military green
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139014
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119257
if you want to water cool I love this cass: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
and you can fit a triple rad with some moding in this: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119245
Im thinking about the cooler master, how much of a difference do you think that CM cooler would have over the 212 Evo? and h100 cost too much
I don't have much opinion on the coolers you've mentioned, but I would suggest looking into the samsung 30nm ram here if you plan on using a tower cooler
(amazon) http://www.amazon.com/gp/product/B00592002W/ref=ox_sc_act_title_5?ie=UTF8&smid=ATVPDKIKX0DER
(newegg) http://www.newegg.com/Product/Product.aspx?Item=N82E16820147096
Pay attention to the fact that the listed CAS11/1600Mhz is at 1.35v, once you increase the voltage to ~1.5v you'll be able to tighten the timings to CAS7-8 at 1600mhz, or CAS9-10 at 1866/2133Mhz. And it's ultra low profile, so you can pretty much buy any CPU heatsink you want without memory clearance problems.
Techpowerup review with overclocking information: http://www.techpowerup.com/reviews/Samsung/MV-3V4G3/
Check out the scythe mugen 3, its a godly beast for the price, i overclocked an i5 2500K with no problem to 4,9Ghz!
For your motherboard i can recommend the asus p8z77-v line of motherboards (there are quite a few variations of it) or the Asus z77 Sabertooth (wich i would of got if i had an extra £20 at the time of my build). and i can recommend the nzxt phantom 410, damn this case is huge and awesome. and meh your graphics card is good but i prefer Nvidia;s line of gpu's
all in all i think your build is good
