Okay, so I'm upgrading my PC and I need it ordered by this weekend. My current build is:
Current specs:
CPU - AMD Athlon II x2 250 Processor
GPU - KFA2 Geforce GTX 660 Stock Clock
PSU - Corsair CX 500
Motherboard - Gigabyte M68MT-S2P
CPU Cooler - Stock Cooler
Sound Card - Motherboard Integrated
Memory - 2x2GB Kingston RAM 1333mhz
Hard Drive - Hitatchi 500GB SATA II 7200RPM
Optical Drive - LG Optical Drive
Case - Mars Blue Micro-ATX
What I want to do with this PC:
Gaming. Mostly WoW (World of Warcraft)
What I thought before was just adding an SSD and getting me some nice new headphones as my old ones broke, however, but also I could get new components E.G CPU to make it run faster.
What I thought of getting is here. Budget is ~£350.
Could someone help by making a build? I do not want to have to touch the components for at least a year, and when I want to make sure ALL the components work together before I buy them, so I wouldn't want to do any BIOS updates. What I would like to do is wipe my HDD, install new hardware, install Windows 7 and that's it, not any BIOS updates, not anything like that, and I would hate to go out and have to buy other components if some are not compatible so if someone could make a build and check it over to make sure all of the components would work right out of the box? I would not want to be stressing over them and why they don't work.
What I will be doing is taking all of the new components fitting them and taking the old components out of my old PC that I need (E.G Power Supply, GPU, HDD) and fitting them, essentially a PC build, but I have never done this before so I would like to be simple and for everything to work.
Thanks so much in advance just for reading. :)
EDIT: I would also like to buy EVERYTHING now for £350 than to find out later I need case fans, etc, so if you could include everything I need E.G case fans, thermal paste please. Thanks again :)
