Help with new Build
Hey all, been watching Wendell since the other channel. new some advice for a new build. Planning on 3080TI or the new 16gb 3080 if the TI don’t exist.
  1. get amd 5600x or better?
  2. i think 3800 mhz ram or higher (which latencies?)
  3. mobo…
  4. PSU (i got a very old corsair 1200 pro ) but i been getting random shutdowns… but I’m not could be due to a number of reasons)
thanks guys
What are you using your PC for? According to GN, the 5600X is enough for gaming.But personally, I wouldn’t go for anything below 8 cores. (Also a tiny bit important, what’s your budget?)
RAM and Mobo would sort of depend on each other. Even though the situation is now different, a few weeks ago I purchased a 4000CL17 kit which my mainboard was only able to run at 3200CL16.
So, for the next kit I purchased I checked that it was on either the mainboard’s Or the RAM manufacturer’s QVL. Thus, I ended up with 3600CL16 sticks. However, make sure they are dual rank (≠ dual channel).
Regarding the mainboard, I went with the Aorus Master X570, but the Asus Dark Hero might also be a nice pick. Then again, both boards are pricey.
Get a good PSU, don’t save money here. For this build I would go with Gold/Platinum and 850-1000W. While this is more than recommend, Ampere has voltage spikes which leads to PSU shutdown on weaker ones.
Edit: Regarding mainboards, @MisteryAngel has a good list at hand
  1. 5600X is sufficient for gaming basically.
    But a 5800X will give you a little bit more performance in other area’s.
  2. I would advice to just get a decent 3600mhz CL16 kit from a good vendor.
    Above that you will likely going to see deminishing returns.
    In my opinion not really worth it.
  3. Mobo: depends on budget and features that are important to you.
    And of course the plans you have with the said system.
    I could recommend a good board if i know your wishes.
  4. Psu i could highly recommend a Seasonic psu.
    Something like a 850W Focus Gold plus.
    Platinum psu’s are a bit overkill for home use as far as i´m concerned.
    But of course it never hurts.
Alrighty, will start to do research what’s available here in HK vendors. cheers!
PSU depends entirely on what kind of GPU you will be sticking in there. A 600W is the bare minimum I’d say, but the days of running dual 300W GPUs and 200W CPUs at stock are largely behind us, meaning you can get away with a 600W. Pretty much, aim for 200W above your maximum power draw. The 5800X are drawing max 215W full system power, meaning a 300W GPU would push that to a 550W PSU, so a 750W would be more than adequate.
Of course, Gold/Plat all the way, don’t skimp if you can help it! :slight_smile:
He is talking about a 3080(ti), a 600W PSU is not the bare minimum in my opinion. As mentioned above, I have heard of spikes that trigger over-current protection. So, I would go with 800W just to be on the safer side.
(I think Linus recently mentioned in the 6900XT’s review that it triggered the protection of his 1KW PSU, so he went with a 1.2KW oO)
