Help with my Gaming Rig Choice
So i want to make a build around an athlon ii x3 450 cpu. My choices so far have led me to a total amount of aound 26k philippine pesos (around 650$). I need a monitor and a windows 8 os. If you guhs could make a build out of the following pricelists from the sites; http://www.gaisano-interpace.com/ , http://nutech.ph/ and http://pcquickbuys.com/ that would be great. And im okay with using a cheap case jsyk. Anyway, here are my components as of now:
CPU: AMD ATHLON II X3 450 (2,800php) 2
GPU: POWERCOLOR RADEON HD 7750 (3,500php) 2
MOBO: Gigabyte GA-970 DS3 (4,000php) 1
WIFI ADAPTER: WIRELESS-N INTEX USB ADAPTER (500php) 2
RAM: 4GB DDR3 w/ HEATSINK CORSAIR (1,250php) 1
HDD: WD 500GB BLUE (2,300php) 2
CASE: COOLERMASTER K281 (2,000php) 3
PSU: THERMALTAKE LITEPOWER 500W (1,800php) 1
OS: WINDOWS 8 SL 64-bit (3,700php) 2
MONITOR: ACER V193HQL 18.5" (3,500php) 2
DVD: ASUS 24x (800php)
TOTAL PRICE: ABOUT 26,150php
My budget is around 22-24k (around 500-600$) for the whole thing with the monitor and os. The cheaper the better. Thanks guys.
Dont mind the numbers at the end (e.g. 2MOBO). Those were format errors.
Hey dude, I'm also Phillipino (or Filipino???) as well!!! :D But I live in Australia though. As for your build...
I'll try to see what I can do.
Thanks man! Its great to see another filipino in the fourums. Hahaha
I don't get the sites the you posted...
The pricelists are somewhere in the sites. Find the pricelist section in nutech and gaisano interpace and go to the download section pcquickbuys. Thanks
I don't get them either. I tried all of them and you have to sign up to receive their parts lists sent to your email.
Is there a different site(s) to look at?
The nutech and pcquickbuys dont need your email.
Shouldve done this earlier lol:
http://nutech.ph/download/NUTECH%20COMPONENT%20PRICELIST.pdf
http://pcquickbuys.com/download/flier-042013.pdf
as for the gaisano interpace your gonna have to use your email. They dont spam though, as far as i know.
So do you have the Athlon II x3 450 CPU already, because I don't see it on those 2 parts lists?
Its listed in the gaisano one although im just a bit worried that it isnt an athlon ii x3 450 because it says athlon64 x3 450 but it could just be a typo. I dont think there are athlon64 models with a 450 at the end. Its priced at 2,800php.
Oh okay that's cool. Check Google to see if there is an athlon 64 x3 450. My old desktop used to have an athlon, still pretty fast (it was in windows xp, with a very old NVIDIA GPU. VERY OLD)
I already did that. All it listed were athlon ii x3 450's so i guess im safe.
Anyone else?
Have you tried looking at pcexpress? filipino here! :D
Yeah theyre prices are more expensive compared to nutech, g.i. And pcquickbuys. And also, pcx dont have athlon ii x3 450.
anyone else?
Okay here you go, sorry for the delay, it takes me a bit longer on foreign sites :)
http://pcx.com.ph/amd-fx4100.html  FX 4100 CPU - $4.7k
http://pcx.com.ph/biostar-a880gz-880g-vpcie-s-l-d3-1654.html  Biostar 880g AM3+ Motherboard - $2.75k
http://pcx.com.ph/g-skill-sniper-8gb-1600-12800cl9d-sr2-2x4.html  G.Skill Sniper 2 x 4 gb DDR3 1600 mHz - $2.8k
http://pcx.com.ph/powercolor-hd7850-2gb-ddr5-256bit.html  PowerColor 7850 2 gb GPU - $8.15k
http://pcx.com.ph/500gb-hitachi-sata-7200rpm.html  Hitachi 500 gb HD 7200 rpm - $2.2k
http://pcx.com.ph/fractal-core-1000.html  Fractal Core 1000 Case - $1.58k
http://pcx.com.ph/fsp-raider-80-bronze-550w.html  FSP Raider Bronze PSU - $2.1k
http://pcx.com.ph/lite-on-22x-ihas-122.html  Lite-On DVD Burner - $820
Total ~$25,100!
Thats gonna total to about 29k with my os, i need something lower priced. ill usually be playing on 720p and i rarely max Out games.I kinda want the price to be around 22k and below. But thanks though. Oll try to see if i can get more money.
Here is a bit cheaper setup, but still have some gaming left in it:
http://pcx.com.ph/corsair-xms3-4gb-xms3-cmx4gx3m1a1333c9-1x4.html  Corsair XMS 1 x 4 gb DDR3 1333 mHz - $1.45k
http://pcx.com.ph/powercolor-hd7770-1gb-ddr5-hdmi.html  PowerColor 7770 1 gb GPU - $5.75k
http://pcx.com.ph/coolermaster-elite-343.html  CoolerMaster Elite 343 Case - $1.3k
http://pcx.com.ph/fsp-hexa-he500-eff-80-500w-2.html  FSP Hexa HE 550w PSU - $1.88k
Total build: $20,850!! Just add your OS and your still under $26k!
Thanks man. I like this one. Ill try get thi build. Thanks.
