http://pcpartpicker.com/p/K2AY <--- here is the commponents. will this build work? THX!!!
http://pcpartpicker.com/p/K1No
Something like this would be better for the $650 mark.
Do you actually think a $30 GPU will be good?
$100 PSU, hue hue hue
Bulldozer CPU when Piledriver is out and 10000x better
1600 ram on an AMD build
>buying windows, 2011+2
Spending more on your motherboard than your CPU
Just go with what SecretAuthor recommended, It's 99.99% better in every way. Sorry if I come off as a twat but I want to point out incorrect things so you can learn.
I don`t want 6 or 8 cores because some programms don´t know how to use that many cores. I did´t found that psu that i will buy it cost 50€ and the psu that i chosed was close to it. In the future (when i have money) I will buy sapphire hd7870 2g and allso i have hard drive, oppticaldrive and os ready so those parts i don´t have yet costs 430€. I JUST WANT TO KNOW DO THIS WORK! BUT THX ANYWAY
1. that psu was close to that psu that I will buy (its 2 times cheaper than 100).
2. amd fx-4170 is good enough for me.
3. in future i will buy same kit of ram so i have 16gt 1600 mhz.
just tell me does this work. thx
