Okay so I'm in a sort of predicament here so I've ordered the parts for my build 3770K,GTX670,16GB RAM and all the other good stuff, my question is I can either afford an h100i or an 120gb SSD what should I get first an SSD or a cooler and overclock the cpu? I plan on heavy editing and gaming so would really appreciate some advice.
The SSD will dramatically speed up your computer, but it won't help with video editing at all unless you're saving your videos to the SSD (which I don't recommend). The overclocks you'll get from the combination of the 3770K and H100i will help with rendering times though.
