So I'm thinking of building a PC. I will use it for gaming and coding, and I'm probably going to use UDK and CryEngine SDK in the future. I live in Sweden and my prefered retialer is komplett.se.
Here's a list of the parts I had in mind: http://pcpartpicker.com/p/1UCvI
I want to be able to play most new games maxed out at 1080p at about 30 FPS.
I do not plan on overclocking anytime soon.
I have about 70 bucks left in my budget, so what do you guys think I should spend the money on?
Should I add some fans, get a better PSU to make it CrossFire-Ready, buy a CPU-cooler, get a better motherboard or just spend the money on a better GPU?
Thank you for your suggestion! The Gigabyte GA-970A-D3P is currently on sale though, which makes it quite a bit cheaper than the MSI 970A-G46. Should I still go for the MSI or should I go for the Gigabyte?
I don't think you'll need more memory than the 8GB you already have selected. I'm a software engineer and my work machine has 8GB and I haven't had any issues with that.
