Help with CX750M and GTX 770 SLI
So, I'm building a new Rig and already bought most of the parts, except for the video cards, and I´m having some trouble trying to figure out if my psu will be able to handle the two 770s.
The psu itself has a 8 pin PCI-E modular plug and a 8 pin EPS 12v (I'm assuming its for a second CPU?) but it came with two pci 6 + 2 cables, and corsair says it's SLI supported, but I read that if I plug one of my 770s in the EPS12 plug I will fry my GPU and possibly my PSU because the pins locations are inverted.
What I want to know is, is there anyway to connect my 2 770s in this same PSU?
Thanks!
BTW: Sorry for the bad english :P
is the rear of your psu like this;
If so then you should have been supplied enough pci-e cables (it state 4 on the corsair site). Use them and only them for your gpu's.
Dont go plugging the 8pin cpu power into a gpu that is going to kill your card.
Your are certainly pushing the limits of the psu if you intend to run sli 770's.
I would recommend getting a more powerful PSU just to be safe, but the CX750M does indeed have the plugs you need for SLI/Crossfire. I know cause I own it
