I am not sure if the AMD Phenom II X4 965 Black Edition processor will pair up with the Gigabyte UD3 or UD5 Mobo, any and all input is appreciated.
Here are links:
CPU http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
Mobo UD3 http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
UD5 http://www.newegg.com/Product/Product.aspx?Item=N82E16813128509
a am3 processor should work fine in a am3+ board by my knowledge.
It would work but it won't give you the same perforamnace as if you had an AM3+ Socket CPU. Both the motherboards are Socket AM3+ .Will you might consider to get an AMD FX-4100 instead? It's just a few more bucks.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103996
thanks, do you know if the FX-4100 is unlocked?
FX 4100 is slower than the Phenom II 955 BE.
http://www.guru3d.com/article/amd-fx-8150--8120-6100-and-4100-performance-review/1
http://nl.hardware.info/reviews/2382/amd-fx-8150--8120--6100--4100-bulldozer-review
So you would reccomend the 965 BE over the FX-4100?
Yes.
though if it was me, i would go 6300...
thanks, do you know if the 6300 is unlocked?
Yes, all FX CPU's are unlocked, all Phenom II's with "BE" or "Black Edition" are unlocked too.
Thank you again. I think ill probably get the 6300 for my rebuild.
