Help with computer build?
Please suggest better parts, cheaper parts that won't change the performance a whole lot (A few frames in gaming is okay).
Processor: AMD FX-8350
Motherboard: AsRock 990fx Extreme3
RAM: 2x8 Kingston HyperX 1866Mhz
Graphics card: EVGA GeForce GTX 670 FTW
Power Supply: XFX Core edition PRO850W
Hard Drive: WD Blue 1TB
SSD (Boot drive): OCZ Vertex 3 60GB
SSD (Game storage): Kingston HyperX 3k 120GB
Case: Corsair Carbide 500R
Optical drive: Plextor PX-891SA
I'm going to purchase this in May sometime, so if there is any parts coming out that i should wait for, please tell me! :D
Also i'm going to use this for a lot of gaming, but also rendering videos quite often.
I think you should drop the ssd if you are low on monney. an ssd only helps speed up whats on it and not game performance. It would save $75 ( if your in the us) if you just got a hdd. your OS and whatever games you have on it  would be faster but In game (after the initial load) performance is the same. if OS speed is worth $75 to you go for it but I advise you to stay away from it. I also think you should try to stick all AMD ( not out of fanboyism) because the parts work together for better performance.
Only do this if the cards (or MOBO if your looking at an AMD chipset) have the same specs and are in the same price range.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150586
I haven done too much research but this card looks good   also look at the games the card comes with. you can try to sell thoes for some $ back.  I will link the card I compared it too as well because  its the card I assumed you had  http://www.newegg.com/Product/Product.aspx?Item=N82E16814130843
good luck :)
having an ssd for games will do nothing for fps. you should use the money you would put into 2 ssd's and buy one larger ssd like the http://us.ncix.com/products/?sku=70080&vpn=ASX900S3-256GM-C&manufacture=AData%20Technology
also unless you need CUDA the 7900 series GPU's form amd will get you $155 in free games. http://www.newegg.com/Product/Product.aspx?Item=N82E16814202006&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
or
http://us.ncix.com/products/?sku=67172&vpn=FX797ATDFC&manufacture=XFX&promoid=1285
here is a sample build. http://pcpartpicker.com/p/t7gw
i used a lager cass amd the fx 8230 instead of the fx 8350. they are the same cpu just clocked a little lower http://www.cpu-world.com/Compare/308/AMD_FX-Series_FX-8320_vs_AMD_FX-Series_FX-8350.html
I'd say look for another motherboard...I have had bad experiences with asrock :/
you can also get a cheaper psu, say a 650 or 750. and drop the ssd you were gonna use for your games. if you keep writing files to that disk, you'll kill the disk faster. get a WD black or something like that.
  An SSD is great for fast loading of your OS but not necessary in a build. You might want to look at this Asus motherboard as it has a reputation of being rock solid. Logan just did a video on it so there is plenty of information about this board. This is the Newegg Canadian link to the board and the price difference is only 10 bucks. It comes with a 5 year warranty as well.
 http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131877&Tpk=asus%20sabertooth%20990fx
The other thing you can look at is the FX6300 processor as this is usually more than enough for any of today’s games. Again, this is the Canadian Newegg price.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819113286
  Again, like others have already said, you can lower the PSU to a 750W which will allow you some expansion later but just insure it is at the very least 80+bronze certified.
I saw a video from Linus where he proved that there is no performance advantage in buying a Nvidia card with an Intel CPU or an Amd card with an Amd CPU. I'll still look into a 7970 though :)
I don't really know what Cuda is for, could you explain to me?
Also i don't live in the US so i don't think i'll get the free games deal unfortunately. :/
And i think the Corsair  500r has more room in it than i'll ever need, also i like the LED colour in that one better :P
Cuda is used in Nvidia gpu's and if you are doing rendering for photoshop (movies) it will drastically improveyour rendering times
I dropped the game storage SSD and just went with one Kingston HyperX 120GB instead, that way i can get a fast boot time and store some of my games there as well.
I'm also changing the PSU and the motherboard, and i'm checking out the fx-6300 atm :)
his build will us almost 500w at load so a 800w-1000w psu would be a good match for his build. it will also give him headroom to upgrade or add a second gpu (if he gets a better mb)
Changed the Motherboard to an ASUS Sabertooth R2.0.
Changed the HDD to WD Black, and went with one 120GB instead.
Changing the PSU to a 750 as well :D
I'm going to render YouTube videos a lot, so should i go with the 670?
if you making them and editing. yes or a 660ti but the more cuda cores the better.
is this (http://pcpartpicker.com/p/tiYN) what your thinking and whats the budget?
That looks good, i tweaked it a little bit http://pcpartpicker.com/p/tkTQ. The problem is that i live in Norway and it's super expensive. I used a currency calculator and this build costs 1855$ here.
So if there are anything you think i should add or change please tell me, but keep it around that price range :)
Also i bought that case and that RAM because they look good, which is important expecially on the case, so i think i'll stick with those parts.
