Wanted to use unreal without the epic games launcher
I have been getting these errors every time I try to build the app
Severity Code Description Project File Line Suppression State
Error C1083 Cannot open include file: 'metahost.h': No such file or directory UE4 M:\Documents\GitHub\UnrealEngine\UnrealEngine\Engine\Source\Editor\SwarmInterface\Private\SwarmInterface.cpp 21
Error MSB3075 The command "..\..\Build\BatchFiles\Build.bat -Target="ShaderCompileWorker Win64 Development" -Target="UE4Editor Win64 Development" -WaitMutex -FromMsBuild" exited with code 5. Please verify that you have sufficient rights to run this command. UE4 C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\MSBuild\Microsoft\VC\v160\Microsoft.MakeFile.Targets 44
Well, the links you provided deal with windows.h, which is the Windows API, which is present on all Windows systems by default i think. Your problem with metahost.h is a different thing. According to this link, metahost.h is supposed to be inside .NET SDK, so you have to find, install and select the right one.
I followed that link for metahost.h, but I am not getting the matching C/C++ tabs in the property pages
I could, but my Linux drive doesn’t have enough space to install and make projects. Also my fedora install has some funky things with finding the directory for my mass storage hard drive
I think there’s a regression in UE4 where they always give you that error code 5 error on any error. Can you verify that you have that missing header? That might be the real problem.
This one:
‘metahost.h’:
It seems to be a problem with WIndows/VS libs.
You might upgrade your Visual Studio Project to VS 2017 and you might get errors like:
1>c:\memspect\vsassert\pch.h(20): fatal error C1083: Cannot open include file: 'metahost.h': No such file or directory
Apparently it used to be part of the Windows 8.1 SDK, but is now in the .Net SDK. Seems like a reasonable change, but now I understand why it breaks backward compatibility.
Check to see if you have a version of the .Net SDK with metahost.h installed. If not, run the Visual Studio installer to install a .Net Framework SDK version.
UE is using a build script and is not tied to Visual Studio build system. You need to track down where to add the include directories in the scripts themselves. It’s in the error message …/…/Build/BatchFiles/Build.bat
Because it’s not on Visual Studio build system, you don’t get all the tabs.
