Help with case choice... Or any other ideas?
Hi guys,
I am torn between 2 cases and welcome an opinion on which is better or a case that beets both of them! A few things you may need to know are that I'm 15 and only have £30-45(£45 is really pushing my budget though) and I am from the UK so prices are different and often work out as more. I would also like a USB 3.0 in the case but it is not necessary as I have 2 on the MoBo, but the case must look good(But any advice is helpful as this is very opinionated :)) and the case must be ATX and fit an MSI Gaming GPU(260mm long).
My current 2 options are:
CiT Vengance: http://www.amazon.co.uk/dp/B0071KZNUY/?tag=pcp0f-21, 4 fans, SD reader, PSU at top(not included), USB 2.0 not 3, cool blue flashy fans XD *Favored due to looks*
OR
BitFenix Berc Alpha: http://www.bitfenix.com/global/en/products/chassis/merc-alpha#specs £35ish, 1 fan(most likely buy more), PSU at bottom, USB 2.0 not 3, simple but stylish, probably good cable management
So what do you guys think? And most importantly is a PSU positioned at the top a bad thing, how bad and will it be bad for thermals(CPU) if I have 2 fans on the side? And will it be a problem turning the side fans off over night while downloading my games?
I know it's a lot of questions but help would be appreciated, thanks guys.
Brandon Harris
You can get a 200R for under 50. Or you might consider the NZXT 210 Elite for around 35-40.
It is a shame that you cannot stretch to 60. You can pick up some pretty high quality chassis around 60-70. Like the Fractal Arc mini which is a really nice mATX
Thank you for replying, but do you know if a PSU at the top with a downwards facing fan is bad?
And I'll take a look at those cases thanks! :)
