Help with building
I am new to this forum, but I have been watching tons of tek videos on youtube. I have recently purchased PC parts and am in the process of assembling them. I am really afraid that I am messing up with the wiring or that I messed up my mobo. Right now everything is done except for putting in the graphics card, finishing up wiring things like SATA, PCI, and the power supply wiring. I've been using the manuals and the how to build a PC video but I've come to a few problems.
Some background knowledge:
My mobo is ASRock 960GM/U3S3 FX
PSU is CX500M
Case is Xon 560
The problem:
Whenever I try and plug the 24 pin power supply plug into the mobo it never clicks into place. I've put pressure into it and it still won't work and I fear I already hurt the mobo too much. I know I'm not putting it in the wrong way because it goes in, just not all the way. Other than that I'm just having wiring problems, which might be solved with a bunch of zipties. Any ideas, tekforum?
Also I will add pictures of what I'm talking about soon if the description does not suffice, I just need to find my camera.
Had a similiar problem with my last build. the 24pin just wouldn't go in so it's either the PSU or the MOBO connector that is the issue.  Do you have access to another PSU or MOBO? if you have another PSU you can try and plug that one into you mobo if it clicks then you know you have to return the PSU and if it doesn't then you have to return the MOBO.  Hopefully your lucky and its the PSU that's the problem
Okay I took your advice and I am gonna look into the mobo and PSU more. When I first saw the 24 pin I wasn't sure if the one missing thing was just as a key to see which way it plugged, or it was just faulty. Excuse me for the blurry laptop image but this is all I have ATM. Does that look normal for a 24 pin plug? That little blur thats black and not silverish like the rest of the 23pins is what I'm talking about, it looks empty. Also there is nothing missing there on the Mobo. Really hope thats all it is. Maybe its just the part that clicks it into place on the outside of the 24pin plug thats messed up, its not large enough or something. Thats all for now. Also I am gonna talk to two friends of mine who I think have background knowledge of computer assembling and computer components. If all else fails I'll swallow my pride and go to some place that assembles computers or something and ask them to look at it/finish it. Heres to hoping nothings damaged.
Pic I am talking about http://imgur.com/KZNUwlc
I'll say when i got my replacement MOBO everything looked the same to me but everything snapped into place perfectly.  I had an MSI mobo and corsair PSU which doing some research seem to have fitting issues perhaps same is true with asrock
