Help with building a PC
-I've decided to get into PC gaming,looking to build one for about 650-750ish if I have to spend a little more for a significant leap in performance I don't mind.I need built in wifi also because I cant plug it to the router.Last thing iam kinda leaning towards a r9 270,but whatever you guys suggest iam sure is good.thanks :)
Okay, we need to know a few things first:
1. What country do you live in?
2. Do you need a monitor, keyboard, mouse, OS, etc.?
Providing those details will influence and give us a better idea of what build is best for you.
-I live in US and I do need a monitor,keyboard and mouse,but iam not including it with the build price
this would be a pretty nice build: http://pcpartpicker.com/p/2RxkQ
A powerful amd 6 core cpu
a mobo that is good for it, and has a possibility for mild overclocking. ( i wouldn't put a FX 83XX series processor in it tho)
The 7870 is still a very capable card, since the R9 270(x) are just rebrands from the 7000 series cards.
8 Gigs of decent ram
1 tb HDD and a 64 GB SSD to speed up your os :)
500W will be plenty for this system
A well reviewed WIFI card
all in a corsair carbide 230T
total would be 693.36$
this would be a beast of a machine for the budget and give you great gaming performance.
hope i helped :)
-yes u did help,thnx :) everything sounds good to me
