Hey guys, So i have a XFX Radeon HD 6770 in my pc on my profile. i was playing a game yesterday and suddenly i saw black dots all over the screen, i restarted my pc and every time it boots i get a BSOD saying it was my graphics driver... so i installed a new driver and still nothing, i reinstalled windows and it still dosn't work. Is it dead? Did the GPU desolder? could i fix this with my heat gun?
Sounds like its dead mate, time for an upgrade.
I would check warranty with xfx depending when you bought the card. Then try the heat gun as a last resort as it will most likely do more damage than good. If all that fails i would pick up 7750 as it will give the same if not better performance.
Good Luck
im getting a Asus 7770 2gb, is this better? im going to try the heat gun trick today until i get the new one.
No point geting a 2gb vershon save some cash and get a 1gb vershon the HD7770 is not powerfull anuff to use 2gbs of vram or buy the HD7790 (much better idea)
http://www.anandtech.com/bench/product/777?vs=776
You could probably get a 7850 for the same price as that 2gb Asus 7770.
wow thanks, guess im getting a HD7790
is the 7790 better then a 650 ti OC edition?
