Is the amd Fx 9590 worth it or should i just go with an 8350 pls.
Thx Guys really helpful
No, most FX-8350's can reach the FX-9590's levels with a good motherboard. The latter is pretty much a show piece product. Then again some do like show pieces. ;)
8350 with a crosshair v formula z or a top tier asrock mobo. and you can match a 9590
The Fx 9370 probably wouldn't be a bad choice since it is the same price as the 8350 at 199 on newegg right now. Im not sure why you would pay the same amount for a lower binned version of the same processor. Maybe I am missing something.
havent looked at prices of 9370 in months so good call still requires one hell of a good mobo.
You'd be better off investing in the cooling/motherboard unless you're willing to spend the extra but I don't think it's worth it personally.
Yeah I think it is still worth it while priced like that. I have no idea how long it will be that price though. I mean just yesterday the 8320 was 129 with free shipping on tigerdirect and now its back up to 160.
