Will the amd 760k run windows 8.1 without a dedicated graphics card or do i need to find a new processer? Help?
The 760K does not have an integrated GPU. You will need one. Regardless of what OS you use.
The 6800K is the APU version of that chip and has a integrated GPU. With that you will not need a GPU.
Thanks bruhÂ
