Hi guys!
I need some help with monitoring my network PCs which connecting through WiFi,
I need to monitor whos downloading torrents or movies and things :)
please help, thanks :)
Hi guys!
There are certain solutions both for the router and for the end-user. If you wish to work from your PC, I suggest https://www.tamos.com/products/commwifi/, but there are other, better solution running on the Unix platform. You can even use Wireshark to this particular end.
ok thanks very much :) but err this commview thing is bit too advance for a noob like me :D
