I'm looking to build a gaming PC,and i am new to the process.I just wanted to come here,and post my PC Parts Picker build (http://pcpartpicker.com/user/ps3tna/saved/1VPM) ,and see if you guys could help me make sure everything is compatible.Thanks in advance for any help.
Budget?
Preferably under $1000.
http://pcpartpicker.com/p/1ffmu
No offence,but i really just wanted to make sure that the build that i set up was all compatible and would run well.
Actually i just realized the missing hard drive and graphics card due to unavailablity.
I mean I wouldn't get that psu, also that mobo in combo with that cpu wouldn't be a choice of mine, but it will all work if thats what you really want.
do not get the le version of that board
also i wouldn't reccomend vengance ram, just usually pretty over priced, also if you're just gaming you don't need 16GB
This build seems good,but could you find a graphics card for under $200 to put in it?Just whatever you think would run best and still be able to do high end gaming.
How does this one look? http://pcpartpicker.com/user/ps3tna/saved/1VRe
GTX 650 in that budget? no. no. no.
http://pcpartpicker.com/p/1fgxC
This is what I would get. Could make something where you spend the full 1000 but seems like you don't want to.
1333Mhz memory though.
This one seems pretty good,i'll probably go with this one,thanks.
I fail to see how his build is better than mine, he didn't include the OS, so it isnt that much cheaper than mine.
Because i already have a Windows 7 disc (i realize i forgot to mention that).
his is 100 cheaper and doesn't have a godawful processor
Just swap the damn processor then.
Alright guys,i just bought all the parts for Manimal's suggested build.Thanks for the help guys.
