Help with a first build question?
I don't know if this is the right section, but its the closest i could find, so I hope its right!
I'm going to be building my first computer with a tight budget of around $600-800 depending on how much junk i can sale on craigslist etc.
My question, however, is it safe to leave parts in the box for longer periods of time?
I plan on buying parts when they go on sale for relatively cheaper than regular (eg. 3570k  for $190 etc etc) and then saving them until i have all my components, spending money when and where I can.
Is this a good way to do it, or should I just suck it up and buy it when I have all of the cash in hand?
Thanks.
Thats how I built my first pc . A little here mobo. cpu here ram there gpu here . took me about 2 months but it was worth the patience . For $40 more at microcenter you can get a 3770k , 3570k is good $600-$800 can actually get you a respectful rig . Is this for gaming?
It's more for music production (already have an interface and what not, but my core 2 duo laptop isn't cutting it anymore) and very light rendering
But I would still like it to be able to play modern title games like Elder Scrolls, GTA 4 (and maybe 5 if it ever comes out) if it fits within the budget still.
Basically, I can suffer gpu wise and just upgrade later, unless i find an amazing deal on some modern card i guess.
if its for music production than thats aspicy meataball!
Also I guess I forgot to add, im building it small (preferably ITX, if not mATX) so I can transport it weekly.
So that pretty much rules AMD out for APUs if I go with ITX and it hurts the price as ITX parts are more expensive, and hardly go on sale i believe.
ive been wanting to do an ITX frag box i love how small they are
No problem building a system that way.  The only real benefit of getting everything all at once is that if something is defective or DOA you can return it to the store for replacement.  When you get it one piece at a time you may have to return it to the Manufacturer which is going to take longer and bit more of a hassle.
Is there any way to test the parts without having a workbench or extra pcs laying around?
Also, I don't think they sell the asrock m8 as a standalone case, but would buying the barebones kit and then adding everything on as I go until I have the full system a good idea?
I think i'd be over paying a bit, as $500 of my budget is going for case, mobo, and psu only...
Throwing in a cpu and gpu (albeit low end or just going with HD4000) within $100-$200 is a tight squeeze with the major 3570k sales just now ending.
I'd advise you to buy everything when you can. If you do have to return something it will be a bit easier, especially if you can pick up most of your stuff from a local Microcenter.
It's really exciting to build your first PC, and you'll be going through builds on pcpartpicker like nobody's business...but wait. Just grab everything at the same time.
Went through a similar experience last year when I built my first rig. I'm happy I waited until I could get everything all at once and put it together. It will drive you crazy now that you have the pc bug, but it's worth the wait.
I think ill do that then.
Only thing I need to worry about is cpu, ram, gpu and HDD since i've pretty much decided to go with the asrock M8 barebones at this point...
Hopefully that goes on sale soon!
Thank you all for your help!
Set the motherboard on the box it came in, plug everything and turn it on. As long as the motherboard isnt shorting on anything you can totally put it together without the case. And a note: when you test everything on the motherboard box, DO NOT put the antistatic bag between the box and the motherboard, that could possibly short the board. So yes you can totally test you stuff without a case or bench. :)
I agree with buying everything at once.  When you buy them piece by piece, they may be a good deal at the time of purchase, but may drop in price to match or lower when you build your PC.
Returns are also a lot easier.
I personally bought my whole system with everything discounted, and gamed on Intel HD 4000, till I picked up my HD 7950 for a nice $210.
