i am looking for a computer that can run games well like BF3 with more then playable fps so should i use the FX 6300 or the Intel I5 3570?can you make a build with one of these for less then $1000?please tell me whats better 6300 or 3570.give me any build you think are good.
The 3570 will be better, but it is in a higher price bracket.
for a $1000 build, this is what I recommend, although you should do some research on your own before you buy any of this
http://pcpartpicker.com/parts/partlist/
http://pcpartpicker.com/p/zA2c
For your price range, the FX 6300 is the better option as it performs very similarly to the 3570k but since it's 100$ cheaper, it allows you to get a much more powerful GPU than you'd get with the i5.
oh wow thank you i didnt know you could fit a 7970 into a build like this and keep it in budget.
