Hi,
I am using a 2950x and ASRock x399 taichi with a Kraken X62 AIO for cooling. I am getting high idle temps, 66 Celsius, reported in the motherboard bios (3.30)
Looking at the ryzen master software when running windows, the temperature is in low 30s.
I realise that there is a 27 degree offset from Tctl to Tdie , But if the motherboard is reporting the higher temperature, would that not mean that thermal throttling will happen much sooner than it would if the correct temperature was being reported on the mb?
Any help greatly appreciated
