I was thinking about upgrading my pc for all the next gen titles, but i really dont know what i should focus my money on. Here's my current build, http://pcpartpicker.com/p/1Nbpd.
I was wondering if i should get a new cpu (i7 or 8350?), or whether to get a new gpu (r9's, 780?)
My budget is around $1200
Thanks
Your pc is very nice still. I mean if you absolutely need to spend 1200 dollars. You could upgrade to 4770k, new motherboard and a r9-290x. You can also just get a 3770k and a r9-290x and save some money.
You would be more than fine with just buying a new gpu in my opinion.
I would get a 3770k and a R9 290x or 780 what ever one is better
Yeah im just worried that my cpu might fall behind if i get a 780, or something similar
Is there a big difference between the 3770k and the 4770k?
not really even you 3570k if its overclocked would keep up with a single 780. I would go with a 3770k as changing motherboards is a pain its a great processor. Dont change motherboard unless you are getting a 4930k and a x79 motherboard not worth it otherwise
a nice system, you should deffinately upgrade the gpu, if you can afford go with the 780, however the amd cards are good so maby the new 290x too. you also should think about upgrading your ram, i just dont think 1600 is good anymore. you can pick up 8gb of hyper x beast 2400mhz for around 60 pounds (80ish bucks) or 16 for about £133. you wont get a bottleneck but id up to ivy-e when its out. :)
