Help Unlock sprint Galaxy s4?
I got an Galaxy s4 from my buddy friends for $200 but its locked on sprint network.
I need to unlock it so its compatible with T-mobile.
The phone was rooted and unlocked to the Baseband Version L720VPUAMDC (by myself)
I popped my T-mobile SIM from my working Moto-G and invalid SIM card notification appeared
help please, i dont want this to be a waste of money =(
I will post photos and images if needed
First off, Sprint phones are NOT compatible with T-Mobile (or any GSM network for that matter). T-Mobile is a GSM carrier, while Sprint is a CDMA carrier - these are two different cellular technologies requiring two different radios. I'm surprised the Sprint version even had a SIM slot, since Sprint doesn't use SIM cards.
Now, assuming the Sprint version does support GSM, there is a matter of frequencies - my understanding is that T-Mobile makes use of two (primarily): 1700MHz and 2100MHz - one is used for upstream, the other downstream. As a result, the phone must support BOTH in order to work on T-Mobiles data network. Most GSM phones don't have support for 1700MHz, so as a result, they are stuck on 2G quad-band GSM... in theory. I, personally, haven't gotten a straight answer on this issue, so I can't say for sure that it won't work, but it will likely be another obstacle. I have been much looking into this for quite sometime as I'd like to trade in my T-Mo Note II for an International Note II for the dev support.
The last, and final obstacle is to get the MSN number for Sprint. Sprint will only give this out if the phone is NOT reported lost/stolen, and the account it's tied to doesn't have any debts, and otherwise in good standing. You can also get the MSN number via app, though root access is needed.
