So I have two phones, and both are the same model, just different capacity. One, I bought new and runs an older version of iOS. The second is damaged, runs the latest version of iOS. The second, is damaged and WiFi, Bluetooth, and Gyroscope do NOT work.
Is there any way I can transfer the notes from the second phone to the first phone without updating the OS?
I can’t use iCloud because WiFi does NOT work.
If they’re just files back them up to your cloud storage of choice or even email them to yourself.
If it’s Apple notes and you have a lot of them back them up to iCloud. You can turn on backup just for notes application if you like. Though going forward I’d suggest you either use iCloud to keep copies of your files or regularly make a backup with iTunes.
Under settings > Apple ID > iCloud you can turn it on there
