[ 9.606]
X.Org X Server 1.17.2
Release Date: 2015-06-16
[ 9.606] X Protocol Version 11, Revision 0
[ 9.606] Build Operating System: Linux 3.13.0-68-generic x86_64 Ubuntu
[ 9.606] Current Operating System: Linux michael-xubuntu-linux 4.2.0-22-generic #27-Ubuntu SMP Thu Dec 17 22:57:08 UTC 2015 x86_64
[ 9.606] Kernel command line: BOOT_IMAGE=/vmlinuz-4.2.0-22-generic.efi.signed root=/dev/mapper/xubuntu--vg-root ro quiet splash vt.handoff=7
[ 9.606] Build Date: 12 November 2015 05:33:29PM
[ 9.606] xorg-server 2:1.17.2-1ubuntu9.1 (For technical support please see http://www.ubuntu.com/support)
[ 9.606] Current version of pixman: 0.32.6
[ 9.606] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 9.606] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
9.606 Log file: "/var/log/Xorg.0.log", Time: Tue Dec 22 13:16:32 2015
9.606 Using config file: "/etc/X11/xorg.conf"
9.606 Using system config directory "/usr/share/X11/xorg.conf.d"
9.607 ServerLayout "layout"
9.607 |-->Screen "nvidia" (0)
9.607 | |-->Monitor ""
9.607 | |-->Device "nvidia"
9.607 No monitor specified for screen "nvidia".
Using a default monitor configuration.
9.607 |-->Inactive Device "intel"
9.607 Automatically adding devices
9.607 Automatically enabling devices
9.607 Automatically adding GPU devices
9.607 The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 9.607] Entry deleted from font path.
9.607 The directory "/usr/share/fonts/X11/100dpi/" does not exist.
9.607 The directory "/usr/share/fonts/X11/75dpi/" does not exist.
9.607 The directory "/usr/share/fonts/X11/100dpi" does not exist.
9.607 The directory "/usr/share/fonts/X11/75dpi" does not exist.
9.607 FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
9.607 ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
9.607 The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
9.607 Loader magic: 0x558584debd40
9.607 Module ABI versions:
[ 9.607] X.Org ANSI C Emulation: 0.4
[ 9.607] X.Org Video Driver: 19.0
[ 9.607] X.Org XInput driver : 21.0
[ 9.607] X.Org Server Extension : 9.0
9.608 xfree86: Adding drm device (/dev/dri/card0)
9.608 xfree86: Adding drm device (/dev/dri/card1)
9.609 PCI:*(0:0:2:0) 8086:1916:1043:1d1d rev 7, Mem @ 0xdd000000/16777216, 0xb0000000/268435456, I/O @ 0x0000f000/64
9.609 PCI: (0:1:0:0) 10de:139a:1043:1d1d rev 162, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
9.609 "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
9.609 "glx" will be loaded by default.
9.609 LoadModule: "glx"
9.610 Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
9.719 Module glx: vendor="NVIDIA Corporation"
[ 9.720] compiled for 4.0.2, module version = 1.0.0
[ 9.720] Module class: X.Org Server Extension
9.720 NVIDIA GLX Module 352.63 Sat Nov 7 20:52:00 PST 2015
9.721 LoadModule: "nvidia"
9.721 Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
9.729 Module nvidia: vendor="NVIDIA Corporation"
[ 9.729] compiled for 4.0.2, module version = 1.0.0
[ 9.729] Module class: X.Org Video Driver
9.730 LoadModule: "modesetting"
9.730 Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
9.731 Module modesetting: vendor="X.Org Foundation"
[ 9.731] compiled for 1.17.2, module version = 1.17.2
[ 9.731] Module class: X.Org Video Driver
[ 9.731] ABI class: X.Org Video Driver, version 19.0
9.731 NVIDIA dlloader X Driver 352.63 Sat Nov 7 20:29:25 PST 2015
9.731 NVIDIA Unified Driver for all Supported NVIDIA GPUs
9.731 modesetting: Driver for Modesetting Kernel Drivers: kms
9.731 using VT number 7
9.733 Loading sub module "fb"
9.733 LoadModule: "fb"
9.733 Loading /usr/lib/xorg/modules/libfb.so
9.734 Module fb: vendor="X.Org Foundation"
[ 9.734] compiled for 1.17.2, module version = 1.0.0
[ 9.734] ABI class: X.Org ANSI C Emulation, version 0.4
9.734 Loading sub module "wfb"
9.734 LoadModule: "wfb"
9.735 Loading /usr/lib/xorg/modules/libwfb.so
9.736 Module wfb: vendor="X.Org Foundation"
[ 9.736] compiled for 1.17.2, module version = 1.0.0
[ 9.736] ABI class: X.Org ANSI C Emulation, version 0.4
9.736 Loading sub module "ramdac"
9.736 LoadModule: "ramdac"
9.736 Module "ramdac" already built-in
9.738 modeset(G0): using drv /dev/dri/card0
9.738 NVIDIA(0): Creating default Display subsection in Screen section
"nvidia" for depth/fbbpp 24/32
9.739 NVIDIA(0): Depth 24, (==) framebuffer bpp 32
9.739 NVIDIA(0): RGB weight 888
9.739 NVIDIA(0): Default visual is TrueColor
9.739 NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
9.740 NVIDIA(0): Option "ConstrainCursor" "off"
9.740 NVIDIA(0): Option "AllowEmptyInitialConfiguration" "on"
9.740 NVIDIA(0): Option "IgnoreDisplayDevices" "CRT"
9.740 NVIDIA(0): Enabling 2D acceleration
9.994 NVIDIA: Allocated GPU:0 (GPU-abc6fc49-741c-03eb-29c4-cb5c52d6d5dc) @
9.994 NVIDIA: PCI:0000:01:00.0
9.995 NVIDIA: Freed GPU:0 (GPU-abc6fc49-741c-03eb-29c4-cb5c52d6d5dc) @
9.995 NVIDIA: PCI:0000:01:00.0
9.995 NVIDIA(GPU-0): Found DRM driver nvidia-drm (20150116)
9.996 NVIDIA(0): NVIDIA GPU GeForce GTX 950M (GM107-A) at PCI:1:0:0 (GPU-0)
9.996 NVIDIA(0): Memory: 2097152 kBytes
9.996 NVIDIA(0): VideoBIOS: 82.07.86.00.13
9.996 NVIDIA(0): Detected PCI Express Link width: 16X
9.996 NVIDIA(0): Validated MetaModes:
9.996 NVIDIA(0): "NULL"
9.996 NVIDIA(0): Virtual screen size determined to be 640 x 480
9.996 NVIDIA(0): Unable to get display device for DPI computation.
9.996 NVIDIA(0): DPI set to (75, 75); computed from built-in default
9.996 modeset(G0): Depth 24, (==) framebuffer bpp 32
9.996 modeset(G0): Option "AccelMethod" "None"
9.996 modeset(G0): RGB weight 888
9.996 modeset(G0): Default visual is TrueColor
9.996 modeset(G0): glamor disabled
9.996 modeset(G0): ShadowFB: preferred YES, enabled YES
9.997 modeset(G0): Output eDP-1-0 has no monitor section
10.001 modeset(G0): Output HDMI-1-0 has no monitor section
10.002 modeset(G0): EDID for output eDP-1-0
10.002 modeset(G0): Manufacturer: AUO Model: 38ed Serial#: 0
10.002 modeset(G0): Year: 2014 Week: 43
10.002 modeset(G0): EDID Version: 1.4
10.002 modeset(G0): Digital Display Input
10.002 modeset(G0): 6 bits per channel
10.002 modeset(G0): Digital interface is DisplayPort
10.002 modeset(G0): Max Image Size [cm]: horiz.: 34 vert.: 19
10.002 modeset(G0): Gamma: 2.20
10.002 modeset(G0): No DPMS capabilities specified
10.002 modeset(G0): Supported color encodings: RGB 4:4:4
10.002 modeset(G0): First detailed timing is preferred mode
10.002 modeset(G0): Preferred mode is native pixel format and refresh rate
10.002 modeset(G0): redX: 0.580 redY: 0.335 greenX: 0.330 greenY: 0.565
10.002 modeset(G0): blueX: 0.155 blueY: 0.140 whiteX: 0.313 whiteY: 0.329
10.002 modeset(G0): Manufacturer's mask: 0
10.002 modeset(G0): Supported detailed timing:
10.002 modeset(G0): clock: 142.0 MHz Image Size: 344 x 193 mm
10.002 modeset(G0): h_active: 1920 h_sync: 2028 h_sync_end 2076 h_blank_end 2100 h_border: 0
10.002 modeset(G0): v_active: 1080 v_sync: 1090 v_sync_end 1100 v_blanking: 1126 v_border: 0
10.002 modeset(G0): Unknown vendor-specific block f
10.002 modeset(G0): AUO
10.002 modeset(G0): B156HTN03.8
10.002 modeset(G0): EDID (in hex):
10.002 modeset(G0): 00ffffffffffff0006afed3800000000
10.002 modeset(G0): 2b1801049522137802bbf59455549027
10.002 modeset(G0): 23505400000001010101010101010101
10.002 modeset(G0): 010101010101783780b470382e406c30
10.002 modeset(G0): aa0058c1100000180000000f00000000
10.002 modeset(G0): 00000000000000000020000000fe0041
10.002 modeset(G0): 554f0a202020202020202020000000fe
10.002 modeset(G0): 004231353648544e30332e38200a00b0
10.002 modeset(G0): Printing probed modes for output eDP-1-0
10.002 modeset(G0): Modeline "1920x1080"x60.1 142.00 1920 2028 2076 2100 1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
10.002 modeset(G0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
10.002 modeset(G0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
10.002 modeset(G0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
10.002 modeset(G0): Modeline "1600x1024"x60.2 103.12 1600 1600 1656 1664 1024 1024 1029 1030 +hsync +vsync (62.0 kHz d)
10.002 modeset(G0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
10.002 modeset(G0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
10.002 modeset(G0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz d)
10.002 modeset(G0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
10.002 modeset(G0): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync (47.7 kHz d)
10.002 modeset(G0): Modeline "1360x768"x60.0 72.00 1360 1408 1440 1520 768 771 781 790 +hsync -vsync (47.4 kHz d)
10.002 modeset(G0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 -hsync +vsync (53.7 kHz d)
10.002 modeset(G0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
10.002 modeset(G0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
10.002 modeset(G0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
10.002 modeset(G0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
10.002 modeset(G0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
10.002 modeset(G0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
10.002 modeset(G0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
10.002 modeset(G0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
10.002 modeset(G0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
10.002 modeset(G0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
10.002 modeset(G0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
10.002 modeset(G0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
10.002 modeset(G0): Modeline "800x512"x120.3 51.56 800 800 828 832 512 512 514 515 doublescan +hsync +vsync (62.0 kHz d)
10.002 modeset(G0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
10.002 modeset(G0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
10.002 modeset(G0): Modeline "720x450"x119.8 53.25 720 760 836 952 450 451 454 467 doublescan -hsync +vsync (55.9 kHz d)
10.002 modeset(G0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
10.002 modeset(G0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
10.002 modeset(G0): Modeline "680x384"x119.6 42.38 680 716 784 888 384 385 390 399 doublescan -hsync +vsync (47.7 kHz d)
10.002 modeset(G0): Modeline "680x384"x119.9 36.00 680 704 720 760 384 385 390 395 doublescan +hsync -vsync (47.4 kHz d)
10.002 modeset(G0): Modeline "576x432"x120.1 40.81 576 608 668 760 432 432 434 447 doublescan -hsync +vsync (53.7 kHz d)
10.002 modeset(G0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
10.002 modeset(G0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
10.002 modeset(G0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
10.002 modeset(G0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
10.006 modeset(G0): EDID for output HDMI-1-0
10.006 modeset(G0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
10.006 modeset(G0): DPI set to (96, 96)
10.006 Loading sub module "fb"
10.006 LoadModule: "fb"
10.006 Loading /usr/lib/xorg/modules/libfb.so
10.006 Module fb: vendor="X.Org Foundation"
[ 10.006] compiled for 1.17.2, module version = 1.0.0
[ 10.006] ABI class: X.Org ANSI C Emulation, version 0.4
10.006 Loading sub module "shadow"
10.006 LoadModule: "shadow"
10.006 Loading /usr/lib/xorg/modules/libshadow.so
10.007 Module shadow: vendor="X.Org Foundation"
[ 10.007] compiled for 1.17.2, module version = 1.1.0
[ 10.007] ABI class: X.Org ANSI C Emulation, version 0.4
10.007 Depth 24 pixmap format is 32 bpp
10.008 modeset(G0): Backing store enabled
10.008 modeset(G0): Silken mouse enabled
10.008 modeset(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
10.008 modeset(G0): DPMS enabled
10.008 modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
10.008 modeset(G0): Option "IgnoreDisplayDevices" is not used
10.289 NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
10.289 NVIDIA: access.
10.311 NVIDIA(0): Built-in logo is bigger than the screen.
10.311 NVIDIA(0): Setting mode "NULL"
10.317 NVIDIA(0): Disabling shared memory pixmaps
10.317 NVIDIA(0): Backing store enabled
10.317 NVIDIA(0): Silken mouse enabled
10.317 NVIDIA(0): DPMS enabled
10.317 Loading sub module "dri2"
10.317 LoadModule: "dri2"
10.317 Module "dri2" already built-in
10.317 NVIDIA(0): [DRI2] Setup complete
10.317 NVIDIA(0): [DRI2] VDPAU driver: nvidia
10.317 RandR disabled
10.320 SELinux: Disabled on system
10.321 Initializing extension GLX
10.321 Indirect GLX disabled.(II) modeset(G0): Damage tracking initialized
10.339 XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
10.346 config/udev: Adding input device Power Button (/dev/input/event2)
10.346 Power Button: Applying InputClass "evdev keyboard catchall"
10.346 LoadModule: "evdev"
10.346 Loading /usr/lib/xorg/modules/input/evdev_drv.so
10.348 Module evdev: vendor="X.Org Foundation"
[ 10.348] compiled for 1.17.1, module version = 2.9.2
[ 10.348] Module class: X.Org XInput Driver
[ 10.348] ABI class: X.Org XInput driver, version 21.0
10.348 Using input driver 'evdev' for 'Power Button'
10.348 Power Button: always reports core events
10.348 evdev: Power Button: Device: "/dev/input/event2"
10.348 evdev: Power Button: Vendor 0 Product 0x1
10.348 evdev: Power Button: Found keys
10.348 evdev: Power Button: Configuring as keyboard
10.348 Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
10.348 XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
10.348 Option "xkb_rules" "evdev"
10.348 Option "xkb_model" "pc105"
10.348 Option "xkb_layout" "us"
10.348 config/udev: Adding input device Video Bus (/dev/input/event4)
10.348 Video Bus: Applying InputClass "evdev keyboard catchall"
10.348 Using input driver 'evdev' for 'Video Bus'
10.348 Video Bus: always reports core events
10.348 evdev: Video Bus: Device: "/dev/input/event4"
10.348 evdev: Video Bus: Vendor 0 Product 0x6
10.348 evdev: Video Bus: Found keys
10.348 evdev: Video Bus: Configuring as keyboard
10.348 Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4/event4"
10.348 XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
10.349 config/udev: Adding input device Video Bus (/dev/input/event5)
10.349 Video Bus: Applying InputClass "evdev keyboard catchall"
10.349 Using input driver 'evdev' for 'Video Bus'
10.349 Video Bus: always reports core events
10.349 evdev: Video Bus: Device: "/dev/input/event5"
10.349 evdev: Video Bus: Vendor 0 Product 0x6
10.349 evdev: Video Bus: Found keys
10.349 evdev: Video Bus: Configuring as keyboard
10.349 Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:22/LNXVIDEO:01/input/input5/event5"
10.349 XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
10.349 Option "xkb_rules" "evdev"
10.349 Option "xkb_model" "pc105"
10.349 Option "xkb_layout" "us"
10.349 config/udev: Adding input device Lid Switch (/dev/input/event0)
10.349 No input driver specified, ignoring this device.
10.349 This device may have been added with another device file.
10.349 config/udev: Adding input device Sleep Button (/dev/input/event1)
10.349 Sleep Button: Applying InputClass "evdev keyboard catchall"
10.349 Using input driver 'evdev' for 'Sleep Button'
10.349 Sleep Button: always reports core events
10.349 evdev: Sleep Button: Device: "/dev/input/event1"
10.349 evdev: Sleep Button: Vendor 0 Product 0x3
10.349 evdev: Sleep Button: Found keys
10.349 evdev: Sleep Button: Configuring as keyboard
10.349 Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
10.349 XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
10.350 config/udev: Adding input device USB2.0 VGA UVC WebCam (/dev/input/event6)
10.350 USB2.0 VGA UVC WebCam: Applying InputClass "evdev keyboard catchall"
10.350 Using input driver 'evdev' for 'USB2.0 VGA UVC WebCam'
10.350 USB2.0 VGA UVC WebCam: always reports core events
10.350 evdev: USB2.0 VGA UVC WebCam: Device: "/dev/input/event6"
10.350 evdev: USB2.0 VGA UVC WebCam: Vendor 0x4f2 Product 0xb54b
10.350 evdev: USB2.0 VGA UVC WebCam: Found keys
10.350 evdev: USB2.0 VGA UVC WebCam: Configuring as keyboard
10.350 Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input6/event6"
10.350 XINPUT: Adding extended input device "USB2.0 VGA UVC WebCam" (type: KEYBOARD, id 10)
10.350 Option "xkb_rules" "evdev"
10.350 Option "xkb_model" "pc105"
10.350 Option "xkb_layout" "us"
10.350 config/udev: Adding input device ELAN1000:00 04F3:0401 (/dev/input/event12)
10.350 ELAN1000:00 04F3:0401: Applying InputClass "evdev pointer catchall"
10.350 Using input driver 'evdev' for 'ELAN1000:00 04F3:0401'
10.350 ELAN1000:00 04F3:0401: always reports core events
10.350 evdev: ELAN1000:00 04F3:0401: Device: "/dev/input/event12"
10.351 evdev: ELAN1000:00 04F3:0401: Vendor 0x4f3 Product 0x401
10.351 evdev: ELAN1000:00 04F3:0401: Found 3 mouse buttons
10.351 evdev: ELAN1000:00 04F3:0401: Found scroll wheel(s)
10.351 evdev: ELAN1000:00 04F3:0401: Found relative axes
10.351 evdev: ELAN1000:00 04F3:0401: Found x and y relative axes
10.351 evdev: ELAN1000:00 04F3:0401: Configuring as mouse
10.351 evdev: ELAN1000:00 04F3:0401: Adding scrollwheel support
10.351 evdev: ELAN1000:00 04F3:0401: YAxisMapping: buttons 4 and 5
10.351 evdev: ELAN1000:00 04F3:0401: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
10.351 Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-5/i2c-ELAN1000:00/0018:04F3:0401.0001/input/input12/event12"
10.351 XINPUT: Adding extended input device "ELAN1000:00 04F3:0401" (type: MOUSE, id 11)
10.351 evdev: ELAN1000:00 04F3:0401: initialized for relative axes.
10.352 ELAN1000:00 04F3:0401: (accel) keeping acceleration scheme 1
10.352 ELAN1000:00 04F3:0401: (accel) acceleration profile 0
10.352 ELAN1000:00 04F3:0401: (accel) acceleration factor: 2.000
10.352 ELAN1000:00 04F3:0401: (accel) acceleration threshold: 4
10.352 config/udev: Adding input device ELAN1000:00 04F3:0401 (/dev/input/mouse0)
10.352 No input driver specified, ignoring this device.
10.352 This device may have been added with another device file.
10.352 config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event10)
10.352 config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event11)
10.352 config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event7)
10.353 config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event8)
10.353 No input driver specified, ignoring this device.
10.353 This device may have been added with another device file.
10.353 config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event9)
10.353 config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
10.353 AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
10.353 Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
10.353 AT Translated Set 2 keyboard: always reports core events
10.353 evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event3"
10.353 evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
10.353 evdev: AT Translated Set 2 keyboard: Found keys
10.353 evdev: AT Translated Set 2 keyboard: Configuring as keyboard
10.353 Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
10.353 XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
10.353 Option "xkb_rules" "evdev"
10.353 Option "xkb_model" "pc105"
10.353 Option "xkb_layout" "us"
11.065 modeset(G0): EDID vendor "AUO", prod id 14573
11.065 modeset(G0): Printing DDC gathered Modelines:
11.065 modeset(G0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
11.340 modeset(G0): EDID vendor "AUO", prod id 14573
11.340 modeset(G0): Printing DDC gathered Modelines:
11.340 modeset(G0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
11.356 modeset(G0): EDID vendor "AUO", prod id 14573
11.356 modeset(G0): Printing DDC gathered Modelines:
11.356 modeset(G0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
12.445 modeset(G0): EDID vendor "AUO", prod id 14573
12.445 modeset(G0): Printing DDC gathered Modelines:
12.445 modeset(G0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
25.604 modeset(G0): EDID vendor "AUO", prod id 14573
25.604 modeset(G0): Printing DDC gathered Modelines:
25.604 modeset(G0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
33.364 modeset(G0): EDID vendor "AUO", prod id 14573
33.364 modeset(G0): Printing DDC gathered Modelines:
33.364 modeset(G0): Modeline "1920x1080"x0.0 142.00 1920 2028 2076 2100 1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
