Ok frick. Just ordered parts for my gaming pc.. So much stress and sh!t. Please tell me if these are good or not, I still have time to cancel the order
Since you didn't include a cooler I'm assuming you won't be OCing.
http://pcpartpicker.com/p/Fec8
Don't buy an incomplete build man. Just get the RAM now. A 6300 is plenty good and won't bottleneck in any way, even with a 7970. I'd take it safe and get a 550 Watt.
this is a bit more then your build but has MUCH better parts
http://pcpartpicker.com/p/Fear
cutting price some
http://pcpartpicker.com/p/Fecu
note: this also cuts the oc potential, IMHO the extreme4 is worth the extra cost.
other then that either would be a good upgrade over what you ordered, the psu is fine, if you decided to add a 2nd 7870xt later, you would need to upgrade it though
EDIT this is better, forgot that ram was from an APU build i helped somebody with http://pcpartpicker.com/p/FefO
this is better ram buy for an 8350 build
sorry this shitty drupal forum removes spaces/line breaks after my links, i have to use "incert horozontal line" to fix it....stupid....they really need to move to something decent, theres a reason very very very few peope use drupal forums.
8Gb vs 4GB for gaming will show you no difference at all, so dont worry about that, maybe something a little faster (1600mhz) would be nice but dont freak out if you have 1333
Also my mobo had a better power phase (4+2 is better than 4+1?) and ratings than the asrock boards so I went with Asus, and my Graphic card is the non xt version
FUCK why did I just do this
Fuck me shit fuck fuck
I do plan on upgrading RAM later on, to 2x4 1866mhz in like a month or so. I was on an extremeley tight budget also, and the 7870 XT version is $30 more, something I can't afford..
Is ram really that important? I played BF3 with 4gb's of 1333 ram before, it wasn't bottlenecking or lagging it at all.
My budget was supposed to be $710 but I went over by like $65..
I'm so freaking nervous right now
How much better is the 7870 XT version than the normal one? I heard its just between the 7870 and 7950.
You could return it if you really feel like that, which in all honesty I'd try and do. The XT is like if the 7870 and 7950 fucked and had a child. It has the power of a 7900 card but has characteristics of a 7800. Noy quite a 7950, not quite a 7870. They run a tad hot but it's no big deal. Should've asked on here before pulling the trigger. The ASrock board isn't a beast or anything, just can't beat it for 85$. The RAM isn't THAT important, but I mean if you have a build like this it's just common sense to throw an appropriate RAM kit on with it, considering it's only like 20$ more than a 4G kit anyways. It's just so cheap it's dumb not to. Just get it while you're spending ya' know? No point buying an unfinished build.
Could you please stop saying stuff about ram..... 1333 to 1600 doesnt change a whole lot, just as 1600 to 1866 wouldnt change a whole lot. Also, he doesnt NEED 8gb. 4gb is plenty, there are just a select few games which require more than 4gb.
I don't like crysis so I'm good for now I guess...
I do plan on upgrading anyways, this is just a temporary solution because of my budget.
Well I'll see how this goes guys, I do plan on updating this thread when I build it and maybe post some benchmarks.
If anything, I'll just throw away my computer and pretend nothing happened. :)... :(
What ever though, it should be good enough for what I do (lots and lots of Blender/Maya, Batllefield3, Sony vegas only to render, not any edit, etc...)
its not actually going to use all of it, most of the "high settings requirements" are BS when it comes to CPU power and memory... do you seriously think a 4150 will run crysis 3 like a 2600k ?
Dude your fine, a 7870 is still a damn good card and has amazing performance for the price, and 1866Mhz ram will soon be dirt cheap soon enough, so just with a little and then get a Good CPU cooler and OC and get some faster ram, you system should still be solid.
