when i connect some cameras to that vlan they connect then they disconnect and continue searching for wifi…
did i mess something up or is this how its suppose to function?
i want to stop them from talking out to internet but still able to stay connected to the wifi so there not searching for wifi…
make model of your setup?.
what software you using?.
have you step by step followed the instruction manual?.
are you running the software that came with the cameras?.
have you installed the latest drivers?.
are there logs you can look at for the application handling the camera?.
they may tell you why its not keeping the connection open.
You may have bought devices that need to phone home in order to function. You may have to redirect their requests out to the internet. It sounds like you may need to employ wireshark to figure out what they are doing.
