Hi im new hear so i would like to intro myself. Names Jon i am from kanadia.
I really need help with Bloodshed Dev C++ which is using miniGW as a compiler in a windows enviroment. I'm new to coding and want to start learning. now i have set up the path C:\Dev-Cpp\bin in Enviroment variables. BUt i keep getting a build error code 1 when i try to compile and run a hello world project made from a tutorial. im finding it hard to figure out wat im missing ect. if any one can figure out wat i missed or recommend a better IDE and compiler to use that would be really helpful. Im also open to other languages if u think there more relevant.
what boov said... go with code::blocks + mingw if you support muh freedomz... or if you want all the .net just microsoft added, go with visual studios.
a c++ hello world should be:
#include <iostream>
int main()
std::cout<<"hello world";
return 0;
a hello world using c should be the following (note: dev c++ is shit, you shouldnt need stdlib, but if i remember correctly it will not compile without it, also im not sure if dev c++ wants the .h's after the header name):
ok guys thanks alot for the replies im gonna ditch dev c++ get code blocks or visual stuido which ever is more accesible to me. (the tutorial i was watching was using dev c that y i chose it)
