hi all,
trying to get the most of this locked 11400f and set it up properly. I’ve already enabled xmp to 3200nhz and set power limits to unlimited using intel xtu.
is it possible to lock all cores to 4.4ghz on the b560 or z590 platform (i.e. use MCE on the locked 11400f)?
the b560 will not allow manually setting core ratios beyond their locked numbers (42x all core, 43x 2 cores, 44x single core), but it will allow setting their turbo ratio to 44x, however this appears to have no effect. -
if 1 is possible, can this also be coupled with a BCLK of 102.9mhz to give 44x102.9= 4.5 ghz?
MCE is not available on gigabyte b560, is it available on asus, msi or asrock? (I have seen it available on asus tuf b560 but does it work?)
option to set BCLK is not available on gigabyte b560, is it available on asus, msi or asrock?
the aurous pro comes with a bclk of 99.75mhz, is there a way to set it to 100mhz?
does b560 support memory overclocking beyond 3200mhz with a 11400f
is there anything else I should set up/change in BIOS for this cpu?
