Hi, everyone!
This is the first time I'm attempting water cooling (and building a rig, for that matter).
Water cooling components I've chosen so far:
radiator:Alphacool NexXxoS XT45 Full Copper 240mm
cpu water block:Alphacool NexXxoS XP³ Light - Black Chrome – Edition
gpu water block:Alphacool NexXxoS NVXP Nvidia GTX780/Titan
reservoir&pumps:Alphacool Repack - Dual Laing D5 Station inkl. 2x Alphacool VPP655
Im going for a black and red theme so im looking for red tubing.I really dont care what colour the fittings are i just wanna be sure they'll fit.I find it really confusing and need some help.
any advice anyone? ;)
You don't need dual d5 pumps for 2 blocks and a radiator.Even one is overkill,you can use a single one at a low speed setting.
Bay reservoir/pump combo's vibrate.I suggest you get a decent pump top and a tube res that fits in your case.It is also 10 times easier to bleed or drain a system that uses a tube res.
Fittings are universal.Their inner diameter is g1/4,its the outer diameter that differs.Just be sure to match the inner diameter of your hose to the outer diameter of your fittings.
3/8 id 5/8 od or 1/2 id 3/4 od hose are the most popular.They don't kink easily.For colored tubing go with primochill or masterkleer,for clear tubing go with tygon.
