Edit #3: NOT SOLVED. DAMMIT. I can receive just fine with the DNS change, but I still can't send from either account.
Hey everyone.
I'm having some issues with my email client. Normally I use Postbox but now next to nothing is working. I've got no idea wtf is up, but here's some foundational stuff:
2 email addresses -Gmail -NameCheap cPanel
2 clients tried - Postbox 3 - Thunderbird
2 hrs spent on the live chat with an NC rep, tried their best to actually help me.
No Avast! firewall. Attempted with Windows Firewall off and with Postbox & Thunderbird "allowed". Tried with modem firewall both on and off.
Webmail works fine, but I really don't like webmail. (I use POP3 on my desktop and IMAP on any mobile devices I happen to be using, which is usually 0.)
I have no idea where to go from here. Please help me out -- I'm suspecting ISP fuckery, but I'd like to either rule that out or be able to show them I've done my due diligence.
Edit: I have attempted it with both SSL/TLS and STARTTLS with each address under each client in all the firewall states. No dice there. I have also tried to allow post Postbox and Thunderbird to autodetect the connection settings for each account, and they fail out, again, in all the states. Thanks @Th3Zone for reminding me to post these.
Have you tried to switch to POP3S or POP3 over STARTTLS? I suspect that G-mail does not accept unencrypted connections anymore; so I would expect it from namecheap;
What if you create a new (duplicate) account in Thunderbird for access in gmail for excample and let it determine how to connect to the POP3/IMAP and SMTP server(s)? Which services and ports does Thunderbird pick? Does the connection fail or does authentication fail?
Actually I've tried both SSL/TLS & STARTTLS for both emails in both clients for all the firewall states.
I don't really want an insecure connection, so that was logical.
As far as allowing either client to autodetect the server configs, neither is able to do that with confirmed good address & password (I use Lastpass, so I manually confirmed).
Probably should have mentioned both of these in the initial post, sorry.
are these the settings you're using when setting up your gmail account?
Email Address: Enter your full Gmail email address Password: Enter your email password Incoming Server: pop.gmail.com Incoming Server Port: 995 Use SSL: Yes Outgoing Server: smtp.gmail.com Outgoing server (SMTP) port: 587 Encryption: TLS
As you use gmail anyway.. you can use googles distributed DNS service: 8.8.8.8 and 8.8.4.4 its really fast, does not filter but most most most likely harvest your DNS queries
I never had any problems with ISP dns so far, except them fucking around with not resolved domains (due to typos) and offering their own add infected search there.
I by now run my own reseolver at home for local DNS and it resolves to the CCC DNS in germany, a DNS in swizerland, a DNS in the netherlands and if everything fails to google.
So I... fixed the cPanel email by staring at it's inbox.... I may be overtired and forgetting that I did something, but if I did I can't remember it. O.o
But Gmail is still being obnoxious. Here's my SMTP stuff.
Server: smtp.gmail.com ( I also tried smtp.googlemail.com ) Port: 587 Auth: Encrypted password Sec: SSL/TLS
