Is it possible to move, or turn off, that annoying top bar in ubuntu unity ?
Or maybe it’s gnome… lol
What Ubuntu version are you using? Newer ubuntus use gnome3
18.04.
Do you mean the system bar? With the clock and stuff? Or the apps bar usually found on the left?
system bar
changed title to better reflect issue and added #helpdesk tag.
https://extensions.gnome.org/extension/545/hide-top-bar/
should do what you want it to.
Thank you. That worked
