hi guys im ordering all the parts for my computer
i need a good usb wifi adapter for my computer, it would be great if it was under or around $40
thanks
thanks
Its slightly too expensive at $50, you may find it on sale for cheap or refurbished somewhere but i personally have 2 of these and they work flawlesslyÂ
thanks for the suggestion, im ordering one now!
awesome! you will not be dissapointed. I have just had really good luck with linksys products and even if you hate it they are really good with returns an customer support, i ordered a router that was DOA and they replaced it and paid the shipping both ways. Good luck with your build!
thx, ill post pictures when the build is done
well? was it good for your particular situation?
