[Help] Python broke apt-get?
Hey I am still pretty green to using linux so I went with pop OS. For some reason though my package manager is not allowing me to update any more I suspect something went wrong with Python 3.8 but I am not sure. when I run an apt-get upgrade python throws errors and prevents me from continuing futher. Ive tried googling the issue to no avail, I suspect I am googling the wrong thing. Ive included the output below. Thanks for your help.
Setting up python3 (3.8.6-0ubuntu1) …
running python rtupdate hooks for python3.8…
dpkg-query: package ‘apt-xapian-index’ is not installed
Use dpkg --contents (= dpkg-deb --contents) to list archive files contents.
Traceback (most recent call last):
File “/usr/bin/py3clean”, line 210, in
main()
File “/usr/bin/py3clean”, line 196, in main
pfiles = set(dpf.from_package(options.package))
File “/usr/share/python3/debpython/files.py”, line 53, in from_package
raise Exception(“cannot get content of %s” % package_name)
Exception: cannot get content of apt-xapian-index
error running python rtupdate hook apt-xapian-index
dpkg-query: package ‘ibus-hangul’ is not installed
main()
Exception: cannot get content of ibus-hangul
error running python rtupdate hook ibus-hangul
dpkg: error processing package python3 (–configure):
installed python3 package post-installation script subprocess returned error exit status 4
Errors were encountered while processing:
python3
E: Sub-process /usr/bin/dpkg returned an error code (1)
Do the following, one line at a time, in a terminal:
sudo apt-get purge python3.8
sudo apt-get update
sudo dpkg-reconfigure -a
sudo apt-get install python3.7
You may not need to perform the last line if apt auto-installs python3.7 to resolve conflicts or if it’s already on your system.
When I type in the first command though, it looks like by default its going to remove my DE (gnome)
try apt-get -f install with sudo.
I get the same terminal output.
Don’t worry about it too much, it’s easy to install again later.
sudo apt-get install gnome
In fact, it might be a good idea to purge Gnome from your system (which means it’ll remove all config files as well as dependencies) and start afresh.
Now, apt is a bit spartan visually, so install aptitude as a package browser:
sudo apt-get install aptitude
Invoke aptitude with:
sudo aptitude
Use Ctrl+t for the menu, navigate with the arrow keys, short-cut keys are indicated in the various menus including a search function, so you should be able to find your way.
Well the down side more so of removing gnome is that pop os has a lot of pre configured gnome themes and stuff but ill try it ive got everything backed up with timeshift so worst case senerio I can revert
It also looks like when i removed python 3.8 it also got rid of many things for other applicaitons, like my nvidia drivers,printers, and a bunch of other libraries. as well as timeshift (the backup utility i was using) so im making a live usb to restore now
you can’t just install those with Apt.
Yea I figured the easiest course of action would be to restore, but that just puts me back to square one, where I cant really upgrade any of my packages. I tried “apt-get -f install” but I get that same error from python
I’m fairly certain there is some dependency hell going on here. Python3 is probably requiring apt-xapian-index but apt-xapian-index also requires Python3 so it’s a chicken and egg situation you’re stuck in since one is installed but not the other I think. Only way out of it is to dpkg install --force the required packages but that has a chance of further breakage if versions aren’t right.
maybe so its werid that I this issue came up becaue previously I wasnt getting this error.
It looked like you were just missing a dependency.
Did you try sudo apt-get install apt-xapian-index ?
Yea but I get the same python error, and it doenst install the package
Would the best thing to restore from a backup from before i got this issue then install apt-xapian-index?
Probably yes. That error blob mentions another package as well, ibus-hangul.
so maybe try to revert to a previous time then install both of those packages?
You were right it was some sort of dependancy hell situation, the way that i resovled it was to revert to a backup where my package manager wasnt broken. Then to install those packages before updating. I wonder though if there would be a way to resolve this without reverting a backup?
Force install the package using the dpkg command I mentioned before but restoring to a nonbroken state is usually the cleanest method.
I was trying to use that command but for some reason it was having issue im guessing that it was typing the command wrong
