Well, these are the most reliable brands, out of all the reviews on any of them they come out better than the rest. Also, you will barely notice the fans, they will probably be way less loud than any of your other parts (im guessing your system doesnt have high-end stuff according to the psu wattage). Also, for your power needs, i should really need to know all the other parts in your system.
When choosing a PSU the two main concerns are Power and Quality of power.
Obv you wanna make sure your PSU can supply the watts for your system, as a ruff guide you want the PSU to be about 20-25% more powerful than your PC needs (this means at any onetime the PSU is around 80% loaded meaning its in its most efficient working zone)
The reason why we like certain brands is because of their qualitity of power and build, you dont want a PSU to be supplying dirty power (high voltage varience) you want them to supply constant clean voltage (low varience).
Brands such as Corair and Seasonic have proven track records in this so this is why they are generally prefered.
Going with unknown brands may save you money to start with but when you start to get blue screens lock ups and random restarts youl be pretty annoyed and worst case scenario you end up frying your brand new cpu/gpu/mob etc or burning your house down :)
