Help please
Hi am building a PC this is how it should look:
Processor-AMD FX 8350 4.0ghz    - 189$
Cooler-  Antec KUHLER H2o water cooling  -58$
 Motherboard -Gigabyte GA-970A-UD3 -102$
Memory - Kingston 1333 8gb (2x4gb) -76$
HDD - Seagate barracuda 1T 7200rpm -62$
Video card - EVGA nvidia GTX 760 2gb. -245$
Case - thermalake v3 black-40$
power supply -EVGA 500  bronze 80plus
I was thinking maybe to buy cheaper video card and better power supply, if u would like to change anything write it down please.My budget is about 850$
Change the motherboard to an Asus m5a99fx pro r2.0 or m5a99x evo r2.0
get some cheaper RAM.  Also get at least 1600mhz. http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
PSU and GPU aren't the best, but are still pretty good.  I would stick with them.
Tnx
do you know some good tech shop eich ships worldwide?
